Encore: DVD video edges are cut off when played on Tv screen
COW Forums : Adobe Encore DVD
Agata Mikolajczyk
on May 29, 2015 at 10:46:47 pm
Hello,
I Edited project in Premiere Pro CC, Exported as Mpeg2, Settings match (so far I tried over 30 different combinations). It looks good when playback on computer. In encore sides are cut to the action safe frame and thats how it plays back on TV. How to scale it down so it will fit properly.
I have been using Adobe for almost 3 years and I never had such a problem. I talked to Adobe support agent and he concluded that probably something is wrong with my TV. I test it on friend’s TV but the issue is the same.
Thank You
Agata
Jeff Pulera
Re: Encore: DVD video edges are cut off when played on Tv screen
on Jun 1, 2015 at 2:53:18 pm
Hi Agata,
Please show a screen grab of the Export Settings window, that will often tell us a lot that we need to know about the situation.
Thank you
Jeff Pulera
Safe Harbor Computers
Agata Mikolajczyk
on Jun 1, 2015 at 5:13:34 pm
Hi Jeff,
This is a screenshot of export settings
Thank you
Agata
Jeff Pulera
on Jun 1, 2015 at 5:23:37 pm
Hi Agata,
Your export format is "MPEG-2" at 1920x1080, when it should be "MPEG-2 DVD" at 720x480 (the only size for NTSC DVD). Please note the "DVD" part of the format. If you send anything else to Encore, it WILL need to transcode the footage again.
Once you choose "MPEG-2 DVD", then select a Preset, such as "NTSC DV Widescreen".
You can manually change the export field order to "Upper" to match the source. You might also adjust the bitrate depending on the length of the program.
Thank you
Jeff Pulera
Agata Mikolajczyk
on Jun 1, 2015 at 6:13:30 pm
Jeff,
It worked on sides (meaning right and left) but now top and bottom are cut off.
Screenshot of settings
Thnk You
Agata
Jeff Pulera
on Jun 1, 2015 at 6:16:05 pm
Your settings look fine, so I would suspect the DVD player. While most will auto-detect whether the DVD should be displayed at 4:3 or 16:9, I have seen some where you must go into the DVD setup menu and tell it what to do. Do you have another player you can test on, or perhaps use the computer with free viewer software such as VLC Media Player?
Jeff Pulera
Agata Mikolajczyk
on Jun 1, 2015 at 7:01:28 pm
In DVD setup menu only 4:3 is available I can’t change it to 16:9. I used friend’s DVD player to check my previous exports and the issue was the same (I will do it again just to make sure). When comes to computer playback regardless of program I’m using: VLC, PowerDVD etc ..It looks fine. Just the TV playback is troublesome.
I also did an export using 2.21:1 aspect ratio and although there are black bars on all four sides making the image smaller I think it looks better than the previous ones. If I won’t be able to figure it out it will be my only option.
Last question just to make sure; is it possible that there is still something wrong with export settings or encore settings? Or as you mentioned before it’s probably the TV display issue?
Thank you
Agata
Jeff Pulera
on Jun 1, 2015 at 7:04:29 pm
Have you changed any defaults/presets in Encore? Basically, if you export an "MPEG-2 DVD" clip as 16:9, and simply Import that into a NEW Encore project using existing defaults, it just ought to work...something is amiss somewhere. I'm assuming that in Premiere, the video fills the Program Monitor view correctly, and also in the Export preview?
Jeff Pulera
Agata Mikolajczyk
on Jun 1, 2015 at 7:09:36 pm
I am using the default Encore setting so it should be fine. As you mentioned in Premiere video fill the monitor correctly, when comes to encore video is cut to fit the safe area.
Jeff Pulera
on Jun 1, 2015 at 7:10:50 pm
How does video look in Encore preview, before burning?
Jeff Pulera
Agata Mikolajczyk
on Jun 1, 2015 at 7:14:01 pm
In Encore preview it looks the way it supposed to look (without any cuts)
Jeff Pulera
on Jun 1, 2015 at 8:04:34 pm
Well then it almost has to be the DVD player
Jeff Pulera
Agata Mikolajczyk
on Jun 1, 2015 at 8:06:22 pm
Ok, tkank you for your help Jeff and have a good day.
