Mov Files Imported Into Encore
COW Forums : Adobe Encore DVD
joe zabrosky
on Feb 18, 2015 at 1:18:15 am
For high quality dvd with 2 hour movie and other files in dvd authoring, should imported files be h264 when importing into encore?
It appears there's no way to export a 2 hr h264 movie file, or some other alternative, in fcpx that would be small enough and qualitative enough to import into encore for dvd creation. Is it standard to have to go to compressor to get the right sized file. If so, what would be the ideal target and maximum bit rate settings to use in compressor?
Thanks for you help! joe
joseph zabrosky
Ricky Barrow
Re: Mov Files Imported Into Encore
on Feb 18, 2015 at 1:56:54 pm
DVD spec for a video DVD (as opposed to Data DVD) is mpg2 video files with Dolby AC3 or PCM audio files. If I did this correctly, here is a link to EXCEL file that will calculate your data rate needs, including any additional ROM content:
8574_rbdvdcalculator.xls.zip
Ricky
joe zabrosky
on Feb 21, 2015 at 12:56:27 am
Thanks Ricky!
joseph zabrosky
