Imported MPEG Corrupt
COW Forums : Adobe Encore DVD
John Perez
on Jan 20, 2015 at 12:00:52 pm
I rendered my MPEG-2. When I play it it's fine, but when I import it into Encore CS6 it has red image at head and tail and is terribly out of sync. What am I doing wrong?
As always thanks so much to you guys...Johnny In Orlando
Jeff Pulera
Re: Imported MPEG Corrupt
on Jan 20, 2015 at 2:49:37 pm
Hi John,
Did you render to "MPEG-2" or "MPEG-2 DVD"? Must be the latter for Encore/DVD compatibility.
If you can post a screen shot of the export settings used, that will be very helpful.
Jeff Pulera
Safe Harbor Computers
Jeff Pulera
John Perez
on Jan 20, 2015 at 10:52:28 pm
The default is "DVD" in the Custom Setting / Output File
John Perez
on Jan 20, 2015 at 10:55:02 pm
FYI: Also, I rendered a short length of the timeline and it was fine when I imported it.
John Perez
on Jan 20, 2015 at 11:20:14 pm
Should I render and import separately video and audio streams? Also, Encore's default setting has lower field priority, but Vegas MPEG default is Upper field first.
Daniel Ludwig
on Jan 21, 2015 at 10:57:42 am
John,
DVD-assets should always be elementary streams, meaning audio + video in seperate files.
acc. to field-order: forget about what encores default, the dedicated field-order you should use with your encoder is depending on the source-file. upper needs to be encoded as upper, lower as lower, otherwise you´ll generate a field-shift, which will luck jurky and like jitter.
danny
John Perez
on Jan 21, 2015 at 11:30:27 am
Thanks, Daniel,
I will do what you suggest. In the meantime I rendered an .AVI file and imported it, and had Encore transcode (?) it. I will get back to you.
Jeff Pulera
on Jan 21, 2015 at 3:38:11 pm
Been a few years since I've worked with Vegas, so I don't recall the exact output settings, but there ought to be some sort of preset specifically for DVD. A Transport Stream is NOT what you want, as Daniel stated.
It is important to have the separate video and audio clips for Encore - anything else will need to transcode (re-encode again). You should have an .m2v video clip, and audio can be .wav or .ac3 (Dolby stereo).
Daniel is also correct about field order. NTSC DV is normally lower field first. If starting with 1080i material, then that is Upper and you can stick with UFF for the DVD, otherwise LFF is normal.
Jeff Pulera
John Perez
on Jan 28, 2015 at 12:45:33 am
Here is a list of the Vegas MPEG output options:
Which should I use?
FYI: I have mixed 1920 X 1080 with 1440 X 1080i on my timeline.
John Perez
on Jan 28, 2015 at 1:32:21 am
Do I pick "MPEG" or "DVD" in my Output Type?
Jeff Pulera
on Jan 28, 2015 at 1:59:49 pm
Sorry but there is no attachment to view
Jeff Pulera
John Perez
on Jan 28, 2015 at 11:36:05 pm
Take Two: 0_mpegoptions.jpg
Jeff Pulera
on Jan 29, 2015 at 2:08:31 pm
Hi Johnny,
For Encore, or any DVD authoring program, you will want to use a "DVD Architect NTSC" preset, standard or widescreen depending on your source. Encore prefers separate video and audio files, not a multiplexed file, so there should also be settings for that within the encoding panel. Maybe you can open the DVD Architect preset and then post the settings panel and we can look that over for you.
Jeff Pulera
John Perez
on Jan 29, 2015 at 10:29:17 pm
Does this apply to Blu-Ray too?
Jeff Pulera
on Jan 30, 2015 at 2:04:15 pm
For Blu-ray, choose a BLU-RAY preset then. While you can use MPEG-2, my preference would be to look at Blu-ray presets under the H.264 format, as H.264 is a newer, more efficient codec.
Jeff Pulera
John Perez
on Feb 1, 2015 at 7:13:01 pm
Jeff, I'm rendering an AVC instead of an MPEG-2 and although my render is very long it's significantly shorter, and my CPU isn't working as hard. Thanks, man... Now lets hope Encore will accept it.
