Background after full motion into Query
COW Forums : Adobe Encore DVD
Douglas Morse
on Dec 14, 2014 at 9:01:36 am
Hi. I want a full motion intro (rolling dice) to be replaced by a still frame after the motion stops. Can't figure out how to do it. Help please.
Stan Jones
Re: Background after full motion into Query
on Dec 14, 2014 at 12:26:28 pm
Check these help pages:
Adobe Encore * Menu timing and looping
http://help.adobe.com/en_US/encore/cs/using/WSF49EA5DB-3743-49c2-9831-F6632...
Adobe Encore * Using After Effects to enhance menus
http://help.adobe.com/en_US/encore/cs/using/WSA5513911-0AD1-440c-BDAD-2E0E8...
While there is no dynamic link between Encore CS6 and After Effects CC, you can use the Encore "Create After Effects Composition" and it will send the psd file to AE CC and create a new composition with appropriate settings. AE no longer has mpeg export, so you export from AE to AME.
Stan Jones
Douglas Morse
on Dec 15, 2014 at 11:58:57 am
I found a simple way to do it. I duplicated the menu, set the animated menu to first play, then I have it switch over to the secondary menu that has the still image on it. The buttons remain the same on both.
