Video audio out of sync once imported to Encore CS6
COW Forums : Adobe Encore DVD
Scott Crowley
on Dec 9, 2014 at 12:55:51 am
Hello Everyone,
I've been having some issues with Encore CS6 for mac lately. I copy VHS to DVD's on the side and burn them through Encore.
The software (Elgato Video Capture) records a .mp4 of the VHS. Usually I just import the video add some chapters it transcodes then burns.
Recently though its started to un-sync the audio. The video will play fine outside of encore but as soon as it's imported in the timeline, the playback and burn are all out of sync. I even used Adobe Media encoder to encode it to an MPEG-2 file before importing, same thing. I then tried to cut off a bit of the audio at the beginning to sync it. It worked for the first 5 minutes, but then again everything else became out of sync.
Has anyone run into this problem before?
Scott
Jeff Pulera
Re: Video audio out of sync once imported to Encore CS6
on Dec 9, 2014 at 2:51:40 pm
Hi Scott,
I've seen this reported when importing a single multiplexed file into Encore (audio and video as one file). Encore prefers separate assets.
When you created the "MPEG-2 DVD" file in Media Encoder, you should've got TWO files, .m2v video and .wav audio. Is that the case?
Jeff Pulera
Safe Harbor Computers
Scott Crowley
on Dec 9, 2014 at 4:44:50 pm
Hello Jeff,
Thanks for the response.
Yes it gave me both files which I imported as a timeline. The video looked way better but the audio was still out of sync.
Scott
