Problems with buttons
COW Forums : Adobe Encore DVD
Mariano Cerdá Cabrera
on Sep 29, 2014 at 2:54:19 am
Hi, sorry if this was already posted, but I couldn't find any solution for this.
So I'm working on this DVD for the first time and I'm using Encore, I have it from Master Collecion CS6 and I have the following problem:
It's a concert DVD and the main menu has a button that leads to the song list of the bands. The problem is that every button is working Except some from 1 of the bands, it's really weird, They are all made the same way, but it seems those from one of the bands won't work, they aren't selectable.
Stan Jones
Re: Problems with buttons
on Sep 29, 2014 at 4:27:13 am
This is usually due to exceeding the button max:
For a DVD 4:3 menu, you can have no more than 36 buttons. For a 16:9 menu, 18 buttons.
Stan Jones
Tim Sutton
on Nov 17, 2014 at 11:59:21 pm
If you have automatic button routing turned on, it might be that your buttons aren't routed correctly.
Click the button on the bottom of your preview window that's circled here: http://i.imgur.com/M5xXLBh.png
Those images on top of the buttons show the button mapping directions, all you need to do is click-and-drag from one button to another as needed. Hope this helps!
