Source is 1080p, do I export as m2v with lower field for standard DVD?
COW Forums : Adobe Encore DVD
chon teck
on Sep 22, 2014 at 4:38:20 pm
Dear all,
I'm using Premiere Pro CC and Encore CS6 but no dynamic link.
Hence I'm planning to export my completed sequence as Mpeg2-DVD and then importing the m2v file into Encore for a PAL DVD.
The original footage is shot in 1080p.
So I'm guessing I should export the m2v in "lower field" as required by PAL DVD? Are there any issues I should take note of if this is the recommended option?
Or do I export as progressive and then let Encore do the conversion? If so, what exactly do I have to do in Encore?
If there's a better solution, plese let me know.
Thanks in advance!
j
Jeff Pulera
Re: Source is 1080p, do I export as m2v with lower field for standard DVD?
on Sep 22, 2014 at 6:52:13 pm
I work with NTSC video and commonly create Progressive MPEG-2 DVD files and use those in Encore, and they do not transcode, don't see why you couldn't do the same in a PAL environment.
Jeff Pulera
Safe Harbor Computers
Daniel Ludwig
on Oct 11, 2014 at 6:47:04 pm
possible - same working with PAL as well. I wouldn´t use lower first - you can go progressive as well.
danny
