Encore Chapter Hightlights Button
COW Forums : Adobe Encore DVD
Ronald Czarnecki
on Sep 1, 2014 at 1:54:34 pm
I duplicated some of the menu buttons and moved them apart. However the second one down is not highlighting with a blue line across. It did burn correctly with the DVD (shown here) however when I made a Blu Ray disc at 26 gb (had to use dual layer 50GB disc) the menu button did not highlight.
Because I can not view the blu ray ISO file before I burn I would like to check as to what might be causing this before I make copies. I do use DVDFab but I guess you have to buy it to view the menus.
Solved I deleted the button and duplicated a new one. Something must have been changed in the button properties.
© 2018 All Rights Reserved
