Work space too large
COW Forums : Adobe Encore DVD
Gerry Condez
on Mar 5, 2014 at 2:24:15 am
Is there an option to fit the workspace in my 20 inch monitor? I cant go to the bottom of the timeline or library to select other options. thanks
Jeff Pulera
Re: Work space too large
on Mar 5, 2014 at 4:24:59 pm
Hi Gerry,
The size of the display is not necessarily the issue - rather, it would be the display resolution. Right-click the Windows desktop and click Properties to bring up the display settings. See if you can increase the resolution used.
Jeff Pulera
Safe Harbor Computers
Gerry Condez
on Mar 5, 2014 at 6:07:21 pm
Thanks, But what if the resolution is maxed out? Its 1680x1050. its a 20 inch cinema display. Is there a keyboard shortcut or option to fit on screen? I cant drag the whole workspace up so for short, I cant resize the window since the lower right corner can not be adjusted.
