code 3 error
COW Forums : Adobe Encore DVD
steve white
code 3 error
on Jan 22, 2014 at 5:36:39 pm
hi guys
got this error
blu-ray error:"device error",code:"3",note:"createstcsequence:fail to write m2s file.
looked it up on the net and it seems to have been around for some time but can't seem to find an answer to it.some have said burn to and iso file and not to disk so i have but even though the disk then burns using imageburn it will not play.The only way i can get it to play is to write it to a folder.
using encore cs6 on a pc.
any help would be great thanks in advance steve white....
Chris Borjis
Re: code 3 error
on Jan 23, 2014 at 9:28:16 pm
Building then burning to disc from encore has always been problematic.
I just "build to folder" then burn the folder with Toast.
always works.
since you are on a pc, I would recommend burning with Nero.
© 2018 All Rights Reserved
