"Copy protected not supported"
COW Forums : Adobe Encore DVD
Keith Betts
on Dec 12, 2013 at 8:34:02 pm
I have used Encore successfully for years. With my most recent project I decided to try to add copy protection for my product. I'm using Encore CS6. I select "No copies allowed" and select CSS "on." However i receive the message "copy protection is not supported for this output option." I'm outputting directly to disc and then duplicating my own copies with a DVD duplicator.
To answer my own question, which I reluctantly dare to do with this forum (!), is the message by Encore prompted by my selection of the output option "Build - Disc?" With my workflow, any suggestions on
how to add copy protection to my DVD copies? Thanks.
Bill Stephan
Re: "Copy protected not supported"
on Dec 12, 2013 at 8:56:47 pm
Keith,
CSS copy protection is only for replicated DVDs. It is added during the glass mastering process by the replicator. CSS does nothing for burned DVD-R discs, since it requires the DVD to be formatted using 2054-bit sectors instead of the 2048-bit sectors used on burned DVDs.
Bill Stephan
Senior Editor/DVD Author
USA Studios
New York City
Keith Betts
on Dec 12, 2013 at 9:08:14 pm
Since i duplicate my own discs any suggestions how I can prevent them from being copied? I'm checking into settings with my duplicator right now. Other than that, any ideas? Thanks.
Jeff Pulera
on Dec 12, 2013 at 9:55:54 pm
Hi Keith,
Bottom line, there is no way to copy-protect your own DVDs, and it's pointless anyway as any 10-year-old using free software can copy any DVD in a few minutes. Put warnings/copyright notices on the package, disc, the video itself as a deterrent, that's all you can do really.
Jeff Pulera
Safe Harbor Computers
eric pautsch
on Dec 13, 2013 at 4:23:47 pm
Besides, if your work is so in demand that pirating is hurting your pocketbook......you'd already be a millionaire :)
Only the studios worry about such things.
There's a saying.....if it can be encrypted, it can be decrypted. Very easily in dvd's case.
