Do I need to do anything special to burn a 8.5 dual layer DVD?
COW Forums : Adobe Encore DVD
Art White
on Dec 12, 2013 at 4:49:55 am
I just got CC but I can't dynamic link from Premiere because I upgraded from CS5 and use Encore CS5 to burn DVDs but I'm way over 4.7gb. I've never used a 8.5 GB dual layer. Encore gives me the option with my burner. Any special instructions for burning and playing a dual layer?
Art
Jeff Pulera
Re: Do I need to do anything special to burn a 8.5 dual layer DVD?
on Dec 12, 2013 at 3:57:04 pm
Hi Art,
How long is the video? You may not need a DL disc - might be as simple as lowering the bitrate. DL discs come with a lot of headaches, such as getting the Layer Break to work properly, compatibility issues with players, more expense, etc.
When manually encoding the MPEG-2 DVD file, use 560/minutes = bitrate, or find an online bitrate calculator app and plug in your specifics.
Jeff Pulera
Safe Harbor Computers
Art White
on Dec 12, 2013 at 4:38:43 pm
Jeff,
Thanks. I did some looking and learned how to lower the bit rate in Adobe Media Encoder, which I've never used before. The video wasn't that long but I experimented with 4 HD cameras this time for a pageant and it ended up being 6.6GB, something I've never experienced before. I bought a few DL DVD's and you are right. They don't give them away. I'm burning one now as a backup and learning experience in case I have to use them.
Thanks for the good contact,
Art
Art White
on Dec 12, 2013 at 5:42:14 pm
Actually, I can't get the DL to burn with an error after ordering files, before building file systems, sorting I get the access denied. Never seen that one before
Stan Jones
on Dec 12, 2013 at 6:21:49 pm
Be sure you run "as administrator" (for PC). Not sure what you call it on Mac. This is different than running under an account with administrative rights.
Stan Jones
Art White
on Dec 12, 2013 at 6:35:27 pm
You mean right click on the Encore project and run as? I'll try that in a bit
Artis White, Producer
Flex Media LLC
Studio:
4983 Sunset Drive
Perrinton, MI 48871
Office: 517 323 8375
flexmedia.tv
Stan Jones
on Dec 12, 2013 at 6:50:10 pm
Yes, "run as." If that is it, you can set it to do that always. With Encore, it is a good idea whether doing du al layer or not. But it has been a deal breaker for dual layer.
Stan Jones
Art White
on Dec 12, 2013 at 7:39:04 pm
Good call Stan,
Burned just fine after that. Odd that was the problem but glad it was!
Thanks Much
Art
Flex Media LLC
Studio:
4983 Sunset Drive
Perrinton, MI 48871
flexmedia.tv
Stan Jones
on Dec 12, 2013 at 8:07:40 pm
Excellent!
Stan Jones
