for inquiry
COW Forums : Adobe Encore DVD
john geagea
for inquiry
on Dec 10, 2013 at 2:53:53 am
Hi.
I'm using adobe cs5.5 and i want to know which setting should choose to prepare the right project at encore cs5.1 to burn it for dual layer 8.5mb
thank you for the help
Jeff Pulera
Re: for inquiry
on Dec 10, 2013 at 3:06:25 pm
Hi John,
What is the source format/sequence setting in Premiere? What is the length of the project to be burned?
Jeff Pulera
Safe Harbor Computers
john geagea
Re: for inquiry
on Dec 11, 2013 at 2:17:06 am
Hi
The format is MPG-2 and the length is 2 hours
thank you
Jeff Pulera
Re: for inquiry
on Dec 11, 2013 at 2:47:58 pm
DVD is always MPEG-2, was asking what footage you were starting with as that can make a difference in workflow. I would recommend against dual-layer DVD, too many headaches/compatibility issues. I've been putting 2 hours or more on 4.7GB DVDs since the technology became available and have never had a client complaint about compression, just use VBR 2-Pass. Set Target to 4.5 for 2 hours.
Jeff Pulera
john geagea
Re: for inquiry
on Dec 12, 2013 at 2:22:35 am
Thank you so much for your advise and i will try to use the 4,7mb as well.
