Advise on Exporting from Adobe Premiere CS5 to Adobe Encore
COW Forums : Adobe Encore DVD
Jamie Sinclair
on Nov 23, 2013 at 11:38:57 pm
Question: I have a wedding I edited in Adobe Premiere CS 5 and I have to create a DVD in Adobe Encore. When I export my project from Adobe Premiere, what settings do I export with before I import it into Adobe Encore? In "format" what do I choose? Is it MPEGS2-DVD, MPEGS2 Blu-ray, etc.??
Please help,
Thank you
Quality over Quantity
Stan Jones
Re: Advise on Exporting from Adobe Premiere CS5 to Adobe Encore
on Nov 24, 2013 at 2:35:13 am
For a DVD, use MPEG2-DVD. If your source was high def, use the "Scale to Fill" in the scaling section of the export.
The bitrate should be calculated to get the highest datarate that fits.
Stan Jones
Jamie Sinclair
on Nov 24, 2013 at 3:22:06 am
Thank you but where is the scaling section where I can use "scale to fill"? I don't see it. The photo I attached is what I see. Please help
Stan Jones
on Nov 24, 2013 at 5:25:36 am
Top left of your image; click the "output" tab.
Sorry that I missed that you are CS5. "Scale to fill" was added with CS6.
Prior to that time, you had to manually crop top and bottom - also in that output window. For NTSC, the last I saw was 12 top and 12 bottom. That was based on the fewest cropped to avoid thin black bars on the sides.
Stan Jones
Jamie Sinclair
on Nov 24, 2013 at 4:41:52 pm
Ok, I chose output tab but the "crop setting" is not highlighted. What do I do next?
