Build and region error (CS6)
COW Forums : Adobe Encore DVD
Filip Olšar
on Oct 23, 2013 at 4:13:36 pm
Hello, I'm using Encore CS6 and during editing of my last project I started to recieve an error with DVD images and DVD discs I exported from Encore. When I export an image, everything seems to be OK in Encore, but when I mount it to Daemon or something and then play in e.g. WMP, the program says, that this DVD isn't meant to be played in my region (but region settings in Encore are set to "All region").
When I build DVD disc from Encore, then the PC doesn't find it as a playable DVD and takes it only as a data DVD...
This bug appeared during editing of one project (I exported 1st version, which was OK. Then I changed one asset and exported 2nd version, which had that bug...) and since then all projects (even old projects that used to be OK) have the same error.
Thanks for any suggestions...
Aaron Stewart
Re: Build and region error (CS6)
on Apr 21, 2014 at 4:10:44 pm
I am having the same issue with my Encore CS6. Have you had any luck in getting this to work again or found a work around?
© 2018 All Rights Reserved
