adobe encore
COW Forums : Adobe Encore DVD
joel schlossberg
adobe encore
on Aug 30, 2013 at 3:14:24 am
i am using finalcutprox to create the video
i tried to burn a blue ray disk and i am getting
an error code3. than i sent the video to a harddrive
and than i made the blue ray disk first 1o minute was
ok tha it broke apart and stopped
Daniel Ludwig
Re: adobe encore
on Sep 2, 2013 at 2:50:36 am
so - what´s your question?
it appears that your transcoded H264-file has been corrupted while encoding.
you need to export the file again from FCP X and start transcoding (again) using compressor.
IF you author the disc within encore you should be able to see if the stream is ok while passing the duration of 10min or not.
© 2018 All Rights Reserved
