audio not playing in encore 5 with preview or timeline
COW Forums : Adobe Encore DVD
Heather Krause
on Jun 9, 2013 at 4:51:01 pm
my audio is not playing anymore in encore 5. It doesn't play from preview or timeline. It does play in PP5 but when I render it out and bring it into compressor 4 I know longer hear the audio here or in encore.
in encore I have motion menus, using compressor set originally to m2v and ac3 but that didn't work. A different thread on here a user with similar problem was suggested to try and use wave files instead in compressor. That hasn't worked either. I guess this is a bug issue or some kind of glitch.... so far I haven't found a cause or solution.
Is my problem in PP or compressor rather then encore?
Stan Jones
Re: audio not playing in encore 5 with preview or timeline
on Jun 9, 2013 at 5:43:22 pm
Since the audio doesn't make it to compressor, I would look to Premiere. For example, did you mute the audio and forget to turn it back on? Not an uncommon cause of no audio...
Stan Jones
Heather Krause
on Jun 9, 2013 at 5:50:28 pm
I was able to work around this issue by rendering my PP file then opening encore and bringing the PP file in as a timeline and skipping encore entirely. My audio is playing now
