Adobe Encore - window not clickable
COW Forums : Adobe Encore DVD
Odil Ruzaliev
on Jun 5, 2013 at 2:19:21 am
I removed the main .*mov file from my computer and wanted to replace it on Encore with another one. But when the program opens, I get a window that says "locate asset", and nothing on that window is clickable nor can I "cancel", "skip" or do anything.
Stan Jones
Re: Adobe Encore - window not clickable
on Jun 5, 2013 at 3:29:45 am
You replace the asset from within Encore. Try putting it back (!); then select it and use "replace asset." Be sure the new file is not named the same.
With it already deleted, I don't know if you can get it to work.
Stan Jones
Odil Ruzaliev
on Jun 5, 2013 at 3:47:52 am
The first file is gone. I can't add another asset or open the program. The window isn't clickable, cancelable, very odd.
Odil Ruzaliev
on Jun 5, 2013 at 3:52:49 am
OK, I just figured it out. Instead of double-clicking the project file, I rather started the Encore first and then clicked on the project name. In this case the locate the asset window became clickable.
