Problem with HCenc and DVD authoring
COW Forums : Adobe Encore DVD
Carlos Angeli
on May 14, 2013 at 3:00:55 pm
Hi, I've been following Jeff Bellune's tutorial on how to encode hd to sd footage, and then using HCenc v0.25 to input an avs file and output it as a suitable mpeg2 file for Encore DVD.
The thing is that now HCenc freezes when selecting the avs file. It's been working flawlessly until now so I have no clue of what's going on. The only workaround I found is using HCenc v0.23 with a YV12 .avi file.
With HCenc v0.25 I could use a YUY2 avi file.
Any thoughts on how to fix HCenc or an alternative compatible with Encore DVD?
Jeff Bellune
Re: Problem with HCenc and DVD authoring
on May 14, 2013 at 3:41:04 pm
What's in your .avs script?
Do you get good quality output from v0.23? If so, I recommend you just go ahead and use that.
The Focal Easy Guide to Adobe Encore DVD 2.0
Carlos Angeli
on May 14, 2013 at 4:07:35 pm
Hi Jeff,
the script reads:
AVISource("720p.avi")
I just use it to open the avi file and export it to mpgeg2.
Previous to that, I'm using a script that reads:
SetMTMode(2,0)
MPEG2Source("Trailer1080p.d2v")
hd2sd(interlaced=false,OutputColorSpace="YUY2")
V0.23 gives me a goo quality too, but I have to export the avi with YV12 (lagarith lossless config.) instead of YUY2, since YUY2 support was introduced in v0.25.
