Encore Cs6
COW Forums : Adobe Encore DVD
Fernando Coelho
Encore Cs6
on May 9, 2013 at 12:49:53 am
I have installed the version Cs6 Encore DVD and create a timeline with my project the following error:
Process: Adobe Encore [326]
Path: /Applications/Adobe Encore CS6/Adobe Encore CS6.app/Contents/MacOS/Adobe Encore
Identifier: com.adobe.Encore
Version: 6.0.1 (6.0.1)
Code Type: X86-64 (Native)
Parent Process: launchd [154]
User ID: 501
Date/Time: 2013-05-08 21:17:17.508 -0300
OS Version: Mac OS X 10.8.3 (12D78)
Report Version: 10
Interval Since Last Report: 194997 sec
Crashes Since Last Report: 23
Per-App Interval Since Last Report: 25633 sec
Per-App Crashes Since Last Report: 22
Anonymous UUID: 6D1FDF90-8050-E2F2-3D8A-D6441DFB6149
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x000000012369aa80
VM Regions Near 0x12369aa80:
MALLOC_TINY 0000000123500000-0000000123600000 [ 1024K] rw-/rwx SM=PRV
--> VM_ALLOCATE 0000000123600000-00000001236e7000 [ 924K] rw-/rwx SM=COW
mapped file 00000001236e7000-00000001239a6000 [ 2812K] rw-/rwx SM=COW /System/Library/Fonts/Helvetica.dfont
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 libsystem_kernel.dylib 0x00007fff91b87d46 __kill + 10
1 com.adobe.dvacore.framework 0x00000001046cf21a (anonymous namespace)::SignalHandler(int, __siginfo*, void*) + 314
2 libsystem_c.dylib 0x00007fff8884694a _sigtramp + 26
3 ??? 0x000000012369aa80 0 + 4889094784
4 com.adobe.Encore 0x0000000100158565 MLFPlaybackHelper::CreateVideoTrack(TrackEditor const&, boost::shared_ptr) + 151
5 com.adobe.Encore 0x000000010015b152 MLFPlaybackHelper::CreateSequence(PGCEditor const&, boost::shared_ptr, bool, int, int, dvacore::geom::PointT, long long, encore::FieldType) + 618
6 com.adobe.Encore 0x0000000100158cd2 MLFPlaybackHelper::GetSequence(PGCEditor const&, boost::shared_ptr, bool, int, int, dvacore::geom::PointT, long long) + 1382
7 com.adobe.Encore 0x00000001001617b0 MLFPlaybackHelper::GetSequence(GUOM::Timeline const*, boost::shared_ptr, bool) + 182
8 com.adobe.Encore 0x000000010057ff76 AuthorContext::EditingServices::InternalCreateTimeline(AuthorContext::StEditingServicesUndoHelper&, GUOM::Timeline*) + 448
9 com.adobe.Encore 0x000000010058060e AuthorContext::EditingServices::CreateTimeline(std::string const&) + 212
10 com.adobe.Encore 0x000000010053ab2f GUOM::Timeline::CreateTimeline(GUOM::ProjectItemContainer*, GUOM::Timeline**) + 501
11 com.adobe.Encore 0x00000001002d62ce ProjectCommands::CreateTimelineHelper(UndoSupport::UndoCookieJar&, GUOM::ProjectItemContainer&, std::basic_string const&, std::list const&, std::list const&) + 77
12 com.adobe.Encore 0x00000001002d7b15 ProjectCommands::AddTimelineHelper(UndoSupport::UndoCookieJar&, GUOM::ProjectItemContainer&, std::list&, UISupport::ProgressStepper*) + 2029
13 com.adobe.Encore 0x00000001002d904f ProjectCommands::CreateTimelineFromCurrSelection(Document*, exo::selection::Manager*, bool) + 215
14 com.adobe.Encore 0x00000001002b0067 encore::ProjectCmdAttachment::DoHandleCommand(int) + 839
15 com.adobe.exo.framework 0x00000001055b25ff exo::uisupport::CommandHandler::HandleCommand(int) + 239
16 com.adobe.exo.framework 0x00000001055b183a exo::uisupport::CommandHandler::DoCallMyCommandChain(int) + 26
17 com.adobe.exo.framework 0x00000001055b0bcc exo::uisupport::CommandHandlerBase::CallCommandChain(int) + 34
18 com.adobe.Encore 0x00000001002fbbf5 encore::ProjectTabController::DoContextMenu(Attribute::Bag*, dvacore::geom::PointT const&, dvaui::ui::UI_Node&) + 8143
19 com.adobe.UIToolkit.framework 0x000000010685a7df exo::hierarchyview::BasicMultiColumnList::DoContextMenu(dvacore::geom::PointT const&, dvaui::ui::UI_Node&) + 79
20 com.adobe.UIToolkit.framework 0x000000010685a78b non-virtual thunk to exo::hierarchyview::BasicMultiColumnList::DoContextMenu(dvacore::geom::PointT const&, dvaui::ui::UI_Node&) + 13
21 com.adobe.exo.framework 0x00000001055af06f exo::trackview::TrackView::ContextMenu(dvacore::geom::PointT const&, dvaui::ui::UI_Node&) + 83
22 com.adobe.exo.framework 0x00000001055ad864 exo::trackview::DVATrackerCapture::DoMouseEvent(dvaui::ui::MouseEvent const&) + 542
23 com.adobe.dvaui.framework 0x0000000104be89dd dvaui::ui::UI_Node::UI_DispatchCapturedMouseEvent(dvaui::ui::MouseEvent const&) + 425
24 com.adobe.dvaui.framework 0x0000000104be8c5c dvaui::ui::UI_Node::UI_DispatchMouseEventToTarget(dvaui::ui::UI_Node*, dvaui::ui::MouseEvent const&, bool) + 118
25 com.adobe.dvaui.framework 0x0000000104be8d0f dvaui::ui::UI_Node::UI_DispatchMouseEvent(dvaui::ui::MouseEvent const&, bool) + 63
26 com.adobe.dvaui.framework 0x0000000104c505e2 dvaui::ui::OS_View::UI_DispatchPlatformMouseEvent(dvaui::ui::MouseEvent const&, bool) + 702
27 com.adobe.dvaui.framework 0x0000000104c4e7aa dvaui::ui::OS_View::UI_DispatchPlatformMouseClickEvent(dvaui::ui::OS_Event const&) + 470
28 com.adobe.dvaui.framework 0x0000000104c4d3c9 dvaui::ui::OS_View::UI_DispatchEvent(dvaui::ui::OS_Event*) + 123
29 com.adobe.dvaui.framework 0x0000000104c4ea98 dvaui::ui::OS_View::UI_HandleOSEvent(dvaui::ui::OS_Event*) + 28
30 com.adobe.dvaui.framework 0x0000000104c4b577 dvaui::ui::OS_View::UI_HandlePlatformEvent(NSEvent*) + 57
31 com.adobe.dvacore.framework 0x00000001045db9de int dvacore::config::ErrorManager::ExecuteFunction(boost::function0*, void*) + 28
32 com.adobe.Encore 0x0000000100227224 dva::encore::DroverErrorManager::ExecuteFunctionWithTopLevelExceptionHandler(boost::function0) + 52
33 com.adobe.dvacore.framework 0x00000001045db8d0 void dvacore::config::ErrorManager::ExecuteFunctionWithTopLevelExceptionHandler(boost::function0, bool*) + 112
34 com.adobe.dvacore.framework 0x00000001045dde0d void dvacore::config::ExecuteTopLevelFunction(boost::function0, bool*) + 125
35 com.adobe.dvaui.framework 0x0000000104c447bf -[DVAMacContainerView mouseUp:] + 127
36 com.apple.AppKit 0x00007fff8b236606 -[NSWindow sendEvent:] + 7053
37 com.apple.AppKit 0x00007fff8b232674 -[NSApplication sendEvent:] + 5761
38 com.adobe.dvaui.framework 0x0000000104c3e586 -[DVAMacApplication sendEvent:] + 630
39 com.adobe.exo.framework 0x00000001055571c3 -[ExoMacApplication sendEvent:] + 563
40 com.apple.AppKit 0x00007fff8b14824a -[NSApplication run] + 636
41 com.adobe.exo.framework 0x0000000105557729 exo::app::OS_AppBase::RunEventLoop() + 55
42 com.adobe.Encore 0x0000000100347260 main + 399
43 com.adobe.Encore 0x00000001000497e8 start + 52
Does anyone know how to solve this problem?
