Too many timelines?
COW Forums : Adobe Encore DVD
Jerel Peterson
Too many timelines?
on Apr 30, 2013 at 2:31:59 am
I've been trying to make a Blu-Ray disc that has almost 180 short timelines. I create playlists and then put links to around 20 timelines for each playlist. But when I get done, everything is all messed up. On my second try on this project, I tested the DVD after setting up each of the first two timelines, and everything was working. So at that point, I just kept going until I was done with all 9 playlists.
But now, no matter which playlist button I click, it goes to the same timeline that is absolutely not in 8 of the 9 playlists. After playing that short timeline, nothing else happens. I have gone back to look at the playlists, and they seem to be exactly as I would want them.
When I close out of the preview window, I get an Internal Software Error.
So, is there a limit to the number of timelines that can be in a project? Could that be causing the problem?
Daniel Ludwig
Re: Too many timelines?
on Apr 30, 2013 at 5:55:50 am
Jerel,
180 timelines are far too much - DVD spec is quite clear. it could contain 99 tracks or stories (which are nearly the same as tracks).
you need to reduce the number of your tracks!
danny
Jerel Peterson
on Apr 30, 2013 at 3:39:34 pm
