Encoded file from Media Encoder says "Un-transcoded" in Encore
COW Forums : Adobe Encore DVD
Adam Berch
on Apr 30, 2013 at 2:14:11 am
Hi Jim,
I just opened up Encore and on my wedding that I encoded from Premiere Pro in Media Encoder then brought into Encore by going to Import ------- as Timeline ---- It says "UnTranscoded" in the Project panel where all of my other assets are.
Should that file be "Transcoded" already?
When I exported it from Premierer into Media Encoder I used H.264 Blu-Ray, PCM Audio and all I did was change the Target and Max Bit Rate settings.
Why is it not already "Transcoded" when I imported it into Encore.
Premiere Pro CS 5.5
Media Encoder 5.5
Encore 5.1
Mac Pro OS X
Jeff Pulera
Re: Encoded file from Media Encoder says "Un-transcoded" in Encore
on Apr 30, 2013 at 2:35:50 pm
In the Encore Project panel, where you see "Untranscoded", expand that window further to the right until you see "Blu-Ray Transcode Status" at the top. For your .m4v file, it should say "Don't Transcode". So you see, when it says "Untranscoded", that is simply stating a fact - that Encore has not transcoded the file. This is NOT saying that it WILL transcode the file. Make sense? At some point, you might have transcoded some of the files in Encore already that needed it, and that would then show the updated status as "Transcoded".
Jeff Pulera
Safe Harbor Computers
