Encore says 21 GB Used -- ISO file is over 25 GB - Why?
COW Forums : Adobe Encore DVD
Adam Berch
on Apr 29, 2013 at 9:54:37 pm
I have set up a DVD in Encore CS 5.1
It is a 2 and a Half hour wedding with 9 Menus and animated buttons.
When I open up the Build tab it says that I am using 21 GB and have 4 left over.
I made an Blu-Ray ISO file and when it was done, it said that the file was 25.75 GB.
Why would it be that much extra? I am trying to burn it in Roxio Toast, but it won't let me because of the size.
How can I make the size smaller so I can make an ISO folder so it's around 22 1/2 GB so I burn it in Toast 11?
Can I do this inside Encore or do I have to re-encode my 2 and a half hour wedding and make the Target Bit rate and Max bit rate a little smaller?
Thanks in advance
Daniel Ludwig
Re: Encore says 21 GB Used -- ISO file is over 25 GB - Why?
on Apr 30, 2013 at 5:57:05 am
Adam,
please look at my other post: http://forums.creativecow.net/readpost/145/872397
