Changing the behaviour of only the last chapter in a feature, Can it be done in Encore?
COW Forums : Adobe Encore DVD
Matt Stoddart
on Mar 19, 2013 at 1:04:12 pm
I've been asked by a client to defeat the "skip to next chapter" command only of the last chapter of a feature.
I'm sure this delving into scripting (if...then...) which seem to be Scenarist territory only but would love to know if this can be done in Encore.
If I had a long enough fade to black near the final chapter point in the feature I could set up another timeline with different properties giving me the desired result, but that is a bit "IF".
Thank in advance.
Matt
Daniel Ludwig
Re: Changing the behaviour of only the last chapter in a feature, Can it be done in Encore?
on Mar 19, 2013 at 5:31:09 pm
Matt,
could you please tell us what system you are using! PC or MAC? is this a allready muliplexed DVD?
then you´ve got only a few options.
cheers
danny
Matt Stoddart
on Mar 19, 2013 at 5:41:33 pm
Hi Danny,
Adobe Encore CS6 on PC and Mac.
This is at the building stage before creating the DDP images for the replicators.
Matt
Daniel Ludwig
on Mar 20, 2013 at 7:52:29 am
ok,
if you are about to mux your stuff, you could easiely use DVD AfterEdit Mastering Edition on MAC to tweek the muxed content.
http://rivergatesoftware.com/dvdafteredit
be awared that this software is running only on MAC OS systems prior 10.7 meaning 10.6 and 10.5.
you could edit the DVD-code and create DDP-images also.
there´s a freeware called mydvdedit, which could not create DDP-images.
for PC there is a similar application, but can´t remember the name at the moment.
cheers
danny
Matt Stoddart
on Mar 20, 2013 at 11:02:38 am
Thanks Danny for that, it's two steps forward and 1 step sideways,
the only Mac I work on is running 10.8, and everything else is PC, I might have to buy an old G4 to run mydvdedit, it looks very interesting.
The PC software wasn't Ifoedit? was it, if you do remember please drop me a line.
It was nice to know that I didn't miss any little trick in Encore and it has to be done using a different programme.
Once the DVD info is edited I can always make a DDP image using Gear Pro.
Matt
Daniel Ludwig
on Mar 20, 2013 at 11:24:45 am
Hi Matt,
yes, correct - that was ifoedit. :)
to use gearmaster for DDP is a very good choice.
cheers
danny
