marker accuracy problem with m2v file
COW Forums : Adobe Encore DVD
alain pire
on Mar 13, 2013 at 2:55:36 pm
I made a live musical film and I want to transcode it onto DVD.
I used FCPX and I exported it to a .mov file (166Gb) - put it into Encore, set my markers ...and everything went fine.
But after checking the video quality on a TV screen, I decided to try to improve it, so I sent the .mov file into Compressor 4 and got a m2v file.
Back into Encore, I cannot set my markers precisely, it leaves a gap between timeline bars and I cannot set it precisely where I want, which is annoying because I need markers to start right a the beginning of a song.
Alain
Roel Bus
Re: marker accuracy problem with m2v file
on Mar 14, 2013 at 2:58:16 pm
Hi Alain,
m2v files are long GOP files, with (depending on your settings, but the default is) an i-frame every 15 frames. That means twice a second. The rest of the frames are interpretive, either forwards or backwards. They do not contain all the information like the i-frames do.
After encoding, Encore does not let you put a marker on anything other than an i-frame, so you can't do frame accurate marking anymore.
That's one reason why markers can not be put where you want it.
Hope this helps,
Roel
alain pire
on Mar 14, 2013 at 3:28:26 pm
Thanks Roel,
So I think that I'll stick to my original uncompressed .mov file which allows me to put markers on a frame basis
Alain
