m2v & m4v on same blu-ray
COW Forums : Adobe Encore DVD
Hagop Goudsouzian
on Feb 26, 2013 at 4:16:50 am
will I have issues down the road if my blu-ray contains mostly m4v and for 3 shorts (3x2min) m2v? So far as blu-ray players compatibility and replication issues and other problems?
Both compressor (h.264) and ame (m4v) regardless of bit rate are giving me problems, yet when I encode m2v, it seems to be fine, only on these three shorts.
Hagop
Bill Stephan
Re: m2v & m4v on same blu-ray
on Feb 26, 2013 at 6:40:28 pm
Unless you are encoding using a high-end spec-compliant hardware encoder such as the Sony or Sonic Blu-ray encoders, forget about using MPEG-2 for Blu-ray. The h.264 for Blu-ray preset in Apple Compressor 3 or 4 is Blu-ray spec-compliant, and you will be able to replicate using these encodes.
Note that Encore will NOT produce a usable BDCMF for replication unless you run your project through Blu Streak Premaster.
Bill Stephan
Senior Editor/DVD Author
USA Studios
New York City
Hagop Goudsouzian
on Feb 27, 2013 at 2:07:40 am
Great! Thank you Bill.
BTW, how much space should I allow for the BDCMF process in case I do need to go to replication, without re-authoring?
I can not do BDCMF myself, I will have to find someone to do it for me (eventually).
Right now I have about 800mb of free space on a single layer BD-R.
Hagop
Bill Stephan
on Feb 27, 2013 at 5:21:40 pm
Our company does not do the premastering process for replicating from Encore, so I cannot give you an authoritative answer. But the size of the assets should not increase because of Blu Streak Premaster.
Bill Stephan
USA Studios
New York City
Hagop Goudsouzian
on Feb 27, 2013 at 7:24:16 pm
Thank you.
