Flash output from encore full screen
COW Forums : Adobe Encore DVD
Jim Smith
on Jan 15, 2013 at 7:48:37 pm
I have created a project with encore which is a 1920x1080 resolution. I want to view on a pc (or Mac) so it is simple to output the encore project as a flash folder, open the outputed flash folder and initiate the index.html. Works fine. My only issue is when opened it is not full screen, it is larger than full screen so you have to navigate to the bottom right corner and click the full screen button then everything is good. ("control F" may also do this). Ideally when the browser is opened it would be in this mode. This is probably more of an HTML function than encore but I thought someone may have come across this and have a solution to make the output initially full screen.
Jim
Bill Stephan
Re: Flash output from encore full screen
on Jan 16, 2013 at 5:12:54 pm
If the resolution of the PC/Mac display card is set for lower than 1920x1080 pixels (most are), your project will display larger than full screen. Set the display card resolution to 1920x1080 or higher.
Bill Stephan
Senior Editor/DVD Author
USA Studios
New York City
