Poor quality menu
COW Forums : Adobe Encore DVD
Ryan Stone
Poor quality menu
on Jan 3, 2013 at 12:13:53 pm
I'm using Encore CS5 on Mac OS X to produce a DVD for a client. They've supplied me with a an SD Widescreen DVD menu at 1080 x 576 px. However, once built, and played on a computer, the menu is rather pixelated and unreadable.
It looks fine on a TV, but I've seen other home-made DVDs that have a crystal clear menu. Any suggestions on what I'm doing wrong would be gratefully received,
Ryan
Stan Jones
Re: Poor quality menu
on Jan 3, 2013 at 1:49:20 pm
PAL? NTSC or PAL, 1080x576 doesn't work. Since CS4, PAL wide, square pixel equivalent, 1050x576.
Stan Jones
Ryan Stone
on Jan 3, 2013 at 2:29:57 pm
Sorry, yes of course that would have been some important information!
It is PAL, so I'll give your dimensions a go.
Many thanks,
Ryan
Ryan Stone | Creative Director
Lambda Films Ltd.
Video Production & Marketing Company
Retina Burn Blog
Online Video, Film & TV Blog
Daniel Ludwig
on Jan 4, 2013 at 4:01:06 pm
if your on pal you should use 1050x576 if you are working with adobe-products. if you are using apple DVD SP you should use 1024x576 (square px) and then scale it to 720x576 for your work or use a PAL 16:9-setting within photoshop, which will be 720x576 with anamorph pixel-aspec.
cheers
danny
Jon Geddes
on Jan 7, 2013 at 11:03:55 pm
Once it goes on DVD, it will be 720x576 with anamorphic widescreen. Encore does a very poor job of scaling menus, so you will want to use Photoshop to scale to that size.
1) Create a 720x576 PAL Widescreen document in Photoshop using the presets.
2) Open your menu and drag all the layers into the new 720x576 document.
3) Position into place and save as a new psd. All layers and button groups should have appropriate Encore prefixes.
4) Import the new psd as a menu into Encore.
This should look much better.
Jon Geddes
http://www.precomposed.com
