Burn a Blu-Ray playable DVD
COW Forums : Adobe Encore DVD
Patrick Simpson
on Dec 13, 2012 at 3:10:59 pm
With Final Cut Pro 7 you could burn HD video to a DVD-R that was playable on a blu-ray player. The process is described here:
http://www.kenstone.net/fcp_homepage/burn_br_mac_superdrive_stone.html
Anyone know if something like this can be done with Premiere Pro and Encore?
Ricky Barrow
Re: Burn a Blu-Ray playable DVD
on Dec 13, 2012 at 3:30:10 pm
I can't explain the process but it can be done in Encore. A person here did that and I saw it work (they are no longer here). I don't know the process. Space is very limited to short video's (maybe 20 +/- minutes).
Ricky
Stan Jones
on Dec 13, 2012 at 3:37:08 pm
Use an Encore Bluray project. Build to a bluray image so the size will fit on a DVD. My recollection is the same as Ricky's - about 20 minutes at whatever the rate was! I use imgburn to burn the BD image onto a DVD. A BD player will play the DVD as a BD. I have heard that some players will not handle this, and I have tested it on only one player.
Stan Jones
Patrick Simpson
on Dec 13, 2012 at 4:48:34 pm
Very interesting. According the FCP article, the burned DVD has an "average bit rate of 14.7 Mbps and a max bit rate of 17 Mbps" due to the limitations of the DVD's red laser. I'm guessing I'd have to limit the data rate with Encore as well.
