CS6 EN Resolution Question
COW Forums : Adobe Encore DVD
Frank Giardina
on Oct 28, 2012 at 7:52:32 pm
Hi All…
Well, I just authored my “FIRST" DVD using Encore. The project was edited it in Adobe Premiere CS6. I was working with 1920 x 1080 DSLR footage. I did a Dynamic Link timeline workflow into Encore. Everything I saw indicated the DVD would be (720x480). I used all the default settings hoping the quality would be acceptable, and it is not.
I could use some encouraging advice everyone. Can I do ANYTHING with the bit-rate or some other setting to help?
Best Sunday Afternoon Regards!!
Frank Giardina
17 Video Production
Daniel Ludwig
Re: CS6 EN Resolution Question
on Oct 30, 2012 at 5:54:08 am
frank,
SD-NTSC DVD is 720x480, and if you have been editing 1080-material it´s like crap in your eye - you get hurt when you see SD vs HD. :D
you´ll get the best SD-resolution if you are going to scale down first prior SD-MPEG2-encoding using a high quality downscale-tool. after effects could do a good job on it.
don´t use HD-content within encore to create a SD-DVD.
cheers
danny
Frank Giardina
on Oct 30, 2012 at 12:42:59 pm
Thanks Danny...
Scaling down will be a first for me... I'll check it out.
Best Morning Regards!
Frank Giardina
17 Video Production
