Why is the disc name on a blu ray disc not showing up in my player?
COW Forums : Adobe Encore DVD
Ian Liuzzi-Fedun
on Oct 27, 2012 at 6:12:19 am
I set the name of the disc in Encore with the name of my program and then the Blu-Ray player just shows BD-R disc. I know that I have seen blu-ray players, specifically mine, show the name of the disc when using professionally made discs. Is there a way to get this all working with Encore?
Using latest CS6 with updates.
Daniel Ludwig
Re: Why is the disc name on a blu ray disc not showing up in my player?
on Oct 30, 2012 at 5:50:49 am
you´ve said it - it has been made on a professional authoring-system, that could implement more meta-data then encore.
cheers
danny
steve white
on Nov 1, 2012 at 1:57:00 am
This can be done if you wright your blu-ray to a folder on your pc.will post a zip file when I get home from work.also adds a picture that displays on the ps3 or pc blu-ray player.
steve white
on Nov 1, 2012 at 12:09:46 pm
Hi Ian
ok now im at home i can walk you through this.
1.Write your blu-ray to a folder and not to disk
2.Close Encore and navigate to the folder on your hard drive.
3.Open up the disk and then open the folder called BDMV.
4.Create a new folder within this and call it META.
5.Open the folder called META and create a new folder called DL
6.Copy the files im sending to you into this folder called DL
7.write the full folder to Blu-Ray disk.thats the folder called BDMV and the folder called CERTIFICATE.
Ok so whats in the files im sending you i hear you ask.well 3 things two jpeg files and a xml file you can edit the jpegs in photoshop or create your own as long as the names stay the same and the size stays the same too.If you change the names then you will have to edit the xml file in notepad and add the new names then save it.the name of your disk is also in the xml file this one just says CREATIVE COW.
best of luck Steve White.
PS: Thinking about doing a tutorial on this now i have an app to record my screen.
steve white
on Nov 1, 2012 at 12:14:21 pm
Sorry the link to the files
http://letitbit.net/download/79681.75086fc35218c3334f557
12fdd6c/creative.rar.html
Daniel Ludwig
on Nov 2, 2012 at 12:10:32 pm
steve,
could you please upload the rar-file to another file-server. There´s a lot advertising and bad popups on that website.
also your link is not complete.
and finally: what you´re describing in your tutorial is a workarround, which pro-apps are doing under the GUI. all in all - it works of course ;)
but encore itself could not create these meta-tags.
cheers
danny
steve white
on Nov 3, 2012 at 8:57:09 am
Danny
Sorry about the bad link hope this one is better.
It says its a zip file but its a rar file.
4904_creative.rar.zip
Daniel Ludwig
on Nov 4, 2012 at 3:48:34 pm
sorry steve,
but the rar-file seams to be corrupted.
could you please upload it again.
danny
steve white
on Nov 6, 2012 at 6:11:07 am
Here you go Danny if this does not work then i can e-mail then to you
regards Steve White......
4912_creative.rar.zip
This is a rar file and when i upload it it seems to be gettinf a zip extention added to it?
Daniel Ludwig
on Nov 6, 2012 at 11:48:03 am
hey steve,
that works perfect now :)
I just wanted to look at the XML-file, as I didn´t have much time to look into one of my authored discs at the moment, and not all of them containing the XML and thumbnails with it.
thx again
danny
Hagop Goudsouzian
on Dec 29, 2012 at 9:14:08 pm
Great! Thanks. Works perfectly. Can this be integrated during the authoring? I usually do my build to an iso, this way I have an extra step before the locked iso.
Christoph Hoffmann
on Jan 7, 2014 at 6:58:43 pm
Hi, first of all thanks for this info, i now get the image and name i want, to be displayed in my PS3 Menu, but the movie cannot be displayed. The disc starts, then the screen turns black and from there straight back to menu with the error, the die file cannot be shown. I have created a Bluray Folder with encore, denn i let me show the Filecontent of die BDMV and created the Folder/Files in there.
I guess my Problem is the burning. i opened Toast, then create a BR Data Disc, there i dragged the 2 Folders "Certificate" and "BDMV" and hit burn.
Am I doing this right, oder is the Problem, that i burn it as a Data-Disc, but i don't know how else i should burn it. I work on a mac, so Toast can burn it for "win/mac" or only mac, should i try only Mac???
Thanks a lot.
