Adobe Encore Menu Loop Point Issue
COW Forums : Adobe Encore DVD
Kevin Murphy
on Sep 20, 2012 at 2:08:40 am
I have been searching the web exhaustively to find a solution to this problem. I have found several similar issues, but nothing quite like mine. I know the Preview function isn't the best, but everything works fine when I check the disc there. It's when I put a burned disc into any blu-ray player that my issue arises. Here's the situation:
I have a blu-ray disc project in Encore. The disc's first play is an "intro" motion menu, :31 in length, with a loop point set to :05 into the video. What I want the disc to do is play that first "intro" menu, have the buttons appear at the loop point, then the menu continues on to the end of the :31 second "intro" menu. At that point, I have a separate, "loop" menu, :30 in length. I want the first menu to jump to the second "loop" menu, which continues and loops "forever."
What actually happens is that first "intro" menu plays to the loop point :05 in, then it jumps to what I have set that "intro" menu's "End Action," which is the beginning of the second "loop" menu.
I don't know why it's doing this. As I said, The Preview shows it properly, and this only happens once I've burned a disc and inserted it into a separate blu-ray player. I've tried the disc on several players, and they all do the same thing.
Any ideas? I'm losing my mind here...
Kevin Murphy
Re: Adobe Encore Menu Loop Point Issue
on Sep 20, 2012 at 2:19:21 am
Also, just to clarify, I'm working in CS5.1.0.342.
Brenny boy
on Oct 3, 2012 at 9:20:35 am
Hi do you really need the loop point on the first menu.
If you left it out would it solve the problem .?
Kevin Murphy
on Oct 5, 2012 at 12:20:46 am
I suppose I don't necessarily, but the design of the menus (just like studio discs you can buy on the shelf) involves a short "intro" to the main menu, after which the buttons and selectors would appear. I ended up doing without this little "intro" to get the project finished on time, but I would still like to be able to create these kinds of menus on future discs. Oddly enough, I created an identical menu on a past project in the exact same way with zero issues. Still don't know what happened.
