Multi Page Menus/overlapping buttons
COW Forums : Adobe Encore DVD
Mike Schmitz
on Sep 17, 2012 at 9:12:26 pm
I have a project that I need to make what is a motion menu with a semi transparent lower 3rd type menu bar, when you select one of the options, it opens another addtion to that lower 3rd with more options. I have come close to doing this with the multi page option. The issue I'm having is only the buttons show up on the 2nd page with the rectangle shape of whatever background is behind the button shows up, but not the rest of the image. What I tried to do is make that a button that does nothing, which appears to have worked, but it's only working for one of the pages, the other does not work. Could this be because of overlapping buttons?
Stan Jones
Re: Multi Page Menus/overlapping buttons
on Sep 18, 2012 at 1:34:15 am
You can't add backgrounds in multipage menus, other than page 0. Basically you can only add highlights.
You can fake some issues by using buttons, but as soon as you try what you appear to be, you'll get overlapping buttons.
Your better option is regular menus. All of each menu remains the same except the lower third and the highlights.
Stan Jones
Daniel Ludwig
on Sep 19, 2012 at 5:06:29 am
mike,
it´s been possible with encore, but you need to do some more work on your multi-page-menu.
you need to "slice" all your elements, to take care about your buttons and as stan has posted - buttons could not overlap as well within BD as within DVD.
you need to take care to get back to the previous menu - mostly with the same buttons at the same places as your previous page.
please look here: http://rivergatesoftware.com/tutorial-12tangos
cheers
danny
