Best practice for 1080P 25 -> BD
COW Forums : Adobe Encore DVD
Tore Jonssen
on Jul 6, 2012 at 9:22:01 am
Tried converting a 1080P25 XDCAM for BD using the presets to 50i in Adobe Media Encoder, bit the interlacing makes the resulting BD play back a little jittery. Any ideas or pointers to a good workflow / conversion setting for 25P material to BD?
Regards,
Tore Jonssen
eric pautsch
Re: Best practice for 1080P 25 -> BD
on Jul 6, 2012 at 4:59:40 pm
The best solution here would be to conform your footage to 23.98 then author a 23.98 BD. I use Cinema Tools for this....hope someone chimes in with an Adobe workflow. There are tons tutorials on line as well
You will also need to adjust audio length and pitch as well
This is a perfect reason why you should always shoot 24p these days :)
Tore Jonssen
on Jul 6, 2012 at 5:03:26 pm
Thx for answering. Any calculations for syncing audio from 25 fps to 23.98 fps?
Regards,
Tore Jonssen
eric pautsch
on Jul 6, 2012 at 9:33:17 pm
Its a 4% pitch down. Heres a good thread to read. Plenty of other on the cow as well:
http://forums.creativecow.net/thread/8/1053356
Tore Jonssen
on Jul 7, 2012 at 6:12:50 am
Thanks a lot, Eric!
Regards,
Tore Jonssen
