Adobe Encore CS6 and MXF files
COW Forums : Adobe Encore DVD
david hare
on Jul 5, 2012 at 4:11:47 pm
OK ill try to explain this. Ive upgraded from cs 5.5 to cs6. I thought id have a play with Encore. I opened up a new project and went to import an MXF file but i keep getting this message.
'The Software that's used to decode the media is not available on this system. Installing the correct decoders for the files you are working with may help to correct the problem'
Ok but if i use dynamic link from Premiere the files work fine and dandy. Also if i open up an old prject that contains MXF files they load but in the monitor menu i just get the red adobe 'media offline' screen.
any ideas people?
© 2018 All Rights Reserved
