Add audio to a menu and have animated buttons with different durations?
COW Forums : Adobe Encore DVD
Laura Nucci
on Feb 10, 2012 at 7:42:39 pm
Hi! I'm trying to do the following, but I don't know how to. I want to have 15 seconds animated buttons on my menu, but I want to have a song on the background which lasts 4 minutes.
When I click in animate buttons, I select the duration for 15 seconds, so that after 15 seconds the animated buttons start over again. BUT, when I link the song to the audio (on properties>motion>audio) the duration gets changed to the duration of the song, so this makes the animated buttons lasts 4 minutes (which is terribly long for rendering and space).
Can I have a song playing in the background completely, then start again when it ends, and, at the same time, having animated buttons that only last 15 seconds and loop infinitely?
Thanks!!
Juan Manuel
Re: Add audio to a menu and have animated buttons with different durations?
on Feb 13, 2012 at 12:21:19 pm
I don't think so, as you would be creating a 15 seconds video track with a 4 minutes audio track, and IIRC, the DVD specification requires both to be the same lenght. I don't think there is a workaround either, so you'll need to render those 4 minutes, which is not that much.
