Encore Blu-ray menu blurry, Content fine
COW Forums : Adobe Encore DVD
Ronald Czarnecki
on Feb 5, 2012 at 11:01:22 pm
I just completed making a DVD in encore which turned out fine. I then went to make a blu-ray using the same menus. The first menu set to play first looked blurry. The rest of the chapter menus looked fine when played in preview. I used the same menu through out which was radiant menu wide
I've attached a picture to show how it looks in the project and how it looks in preview.
I did render out the project, I don't know what to look at. Anything I could try? Thanks
Jeff Pulera
Re: Encore Blu-ray menu blurry, Content fine
on Feb 6, 2012 at 2:30:28 pm
Hi Ronald,
Only a few of the menu templates are HD, and they are named as such. If your Blu-ray menu is blurry, it is likely an SD resolution and that is why.
Jeff Pulera
Safe Harbor Computers
