Transcoding in Encore
COW Forums : Adobe Encore DVD
Bob Mane
on Jan 22, 2012 at 8:03:11 pm
im using vegas and need to set - flexible - chapter points in encore, so my understanding is i have to render a non-compliant file and use "Transcoding in Encore" in order to set those chapter markers where i want.
is there some format that would be best for this?
i am hoping i can come up with a workflow that lets me
1. render once from vegas
2. set chapter markers in encore
3. transcode / build in encore in for flash - dvd - bluray.
avi? h264? mpeg?
Jeff Pulera
Re: Transcoding in Encore
on Jan 23, 2012 at 2:26:31 pm
Hi Bob,
From Vegas, Export to the "H.264 for Blu-ray" format, should result in .m4v and .wav audio files that you can then Import into Encore. Add your chapter markers, and create menus. Burn the Blu-ray disc.
Encore will allow you to switch the project format - just change to DVD and you can use the same project with chapters/menus intact. The Blu-ray files will be transcoded to DVD.
I've not done a Flash output, but you ought to be able to do that as well from the same original Blu-ray project. Maybe you want to use "Save as" from the Blu-ray job to create copies to work with for DVD and Flash output.
Jeff Pulera
Safe Harbor Computers
Bob Mane
on Jan 23, 2012 at 3:18:53 pm
"H.264 for Blu-ray"
what is that under? avi, main concept??
