5.1 .ac3 Audio Transcoding Issue
COW Forums : Adobe Encore DVD
Matthew Smith
on Jan 22, 2012 at 9:06:57 am
Hey,
I received a 5.1 ac3 file from the projects sound guy for burning to DVD. The issue is that when imported into Adobe Encore the DVD Transcode is set to "automatic". This is usually something that happens when the file is non-compliant with DVD standards. In this case though I can burn a Blu-ray disc with the same 5.1 audio on the settings, "Don't transcode" and it works fine.
From what I have read of Adobe Encore Transcoding it appears that it could have something to do with the bitrate of the audio, but, due to my inexperience at Authoring of DVD's I can't say for sure.
Daniel Ludwig
Re: 5.1 .ac3 Audio Transcoding Issue
on Jan 26, 2012 at 10:18:12 am
hi,
if you´ve created a valid 5.1-DVD-AC3-file it could also be used for blu-ray without transcoding.
If your project-transcoding-settings set to dolby digital for audio, everything should be fine and your audio wint be transcoded.
cheers
danny
Matthew Smith
on Jan 28, 2012 at 1:33:47 am
Thanks for the reply,
It turned out that the bitrate of the audio was too high for the DVD to be able to set the "Don't Transcode" options.
