Encore exporting stereo files from surround source
COW Forums : Adobe Encore DVD
Michael Kane
on Jan 22, 2012 at 2:57:53 am
I'm using Premiere CS3 with Encore. I have exported the timeline to Encore using the Surcode surround plugin. The surround works fine in Premiere, but when I burn the dvd the dvd only plays back the sound in stereo. Is the problem with the export from Premiere or at the burning stage with Encore?
Matthew Smith
Re: Encore exporting stereo files from surround source
on Jan 22, 2012 at 10:06:13 am
Have you made sure you have selected "Do not transcode" on your audio file in the properties menu in Adobe Encore? If you haven't it will encode into stereo.
If that doesn't help you could check the audio by re-importing the surround sound file that you exported into Premiere and check to make sure there are 6 channels.
Matt
