high quality in a dvd
COW Forums : Adobe Encore DVD
Jason Carr
on Jan 14, 2012 at 1:00:06 am
Hello everytime i create a timeline, encore compress my video a .mv2 file in to 600 mb and its not lettin
me use the hole capacity off the dvd, i want to achieve the best quality possible. its also possible to burn a
hd video in a dvd? its a 10 minute video and i would like to burn it with a dvd menu in 1080
thank you in advance and excuse me for my poor english
Chris Tompkins
Re: high quality in a dvd
on Jan 14, 2012 at 3:25:17 pm
You can create AVCHD Discs on 4.7GB DVD-R's that will play in some Gaming consoles and some DVD Players. You cannot burn a Bluray compliant files on to a SD DVD.
Is your footage HD at the start?
Export out of APP sending it to AME and choose the DVD mpeg2 preset, alter it as needed. Shows you the est. file size at the bottom as you adjust the data rate.
Chris Tompkins
Video Atlanta LLC
Daniel Ludwig
on Jan 15, 2012 at 6:40:04 pm
NOTE: AVCHD can´t be played in any DVD-player
it´s a sub-format of Blu-ray, could only played on BD-players.
cheers
danny
Jason Carr
on Jan 17, 2012 at 12:56:48 am
thanks
Jeff Pulera
on Jan 16, 2012 at 7:32:26 pm
Hi Jason,
Others have responded to the HD question.
At "maximum quality", a DVD will hold 60 minutes of video - it is not possible to fill the disc with only 10 minutes of content, as a data rate that high would be out of spec and not work with players.
You can use Adobe Media Encoder out of Premiere to manually encode to "MPEG-2 for DVD". Set quality slider to "5" and encode with CBR encoding at setting of "8".
Jeff Pulera
Safe Harbor Computers
Jason Carr
on Jan 17, 2012 at 1:01:49 am
nice now i have a good idea i was a little bit lost thank you
