Encore Media Cache?
COW Forums : Adobe Encore DVD
Vin Alsace
Encore Media Cache?
on Dec 21, 2011 at 4:03:20 am
System: Windows 7
Encore CS5
I have an encore project that in a previous saved version had a subtitle track turned on as a default. In the disc properties, I had "Set Subtitle: 1". "1" was my subtitle track. This worked fine and I created .iso files with this that worked correctly.
I wanted a version where the subtitles were turned off as the default, so I "Set Subtitle: Off" in the Disc Properties. I saved the encore file, went into Edit > Preferences > Media: Delete Media Cache.
I checked the project. There were no errors. I built the ISO again. When I mounted the iso on Virtual Clone Drive to test it, this new version still has the subtitles set to "on" as the default.
I wasn't even sure this was a media cache issue, but thought it might be. Does anyone know what could be causing these subtitles to continue to be turned on as a disc property, even though I have them turned off?
© 2018 All Rights Reserved
