Exporting to Mini-DVD from Encore CS5?
COW Forums : Adobe Encore DVD
Robert Dodrill
on Dec 7, 2011 at 11:46:08 pm
I'm working on a couple of commercials and the client asked for a copy on mini-dvd (and yes I confirmed mini-dvd and not mini-dv).
I'm using a dynamic link from Premiere CS5 and can burn regular DVDs just fine. However, when putting in this mini-dvd it doesn't show up. The only disc options are dvd, blu-ray, and flash. Under Disc Info Settings the available sizes remain the three defaults.
So I put in custom and entered 1.4gb because it seemed logical. I did a check and there were no errors, and then burned the disc and it all went through.
Here is where the problem comes in, I put the mini-dvd back in to play and nothing. My computer doesn't even recognize a disc in the tray. I tested on a dvd player and the same result.
Oddly when putting a blank disc in, my computer prompts me that it's blank and able to burn.
So am I missing a setting here? Are Mini-DVDs compatible to burn with Encore?
By the way these is the discs that I picked up:
http://www.amazon.com/Sony-10DMR30RS1H-DVD-R-10-Pack-Spindle/dp/B001588QRA/...
Chris Tompkins
Re: Exporting to Mini-DVD from Encore CS5?
on Dec 8, 2011 at 1:20:02 pm
They should just burn like a 4.7 disc but less space.
Create files and burn it with another software?
Chris Tompkins
Video Atlanta LLC
