Encore CS5 crashes a few seconds after starting
COW Forums : Adobe Encore DVD
Paul van der Bergen
on Dec 7, 2011 at 3:59:22 pm
Hi !
I've a huge problem with Adobe Encore CS 5:
The program starts, I can make a new project, but after 5-10 sec., it crashes. Even if don't do anything (e.g import or make a menu), it just shuts down and I get an error-message.
I deactivated the DVD-Player, deleted the appdata, made a new user, opened as administrator, deactivated the windows-compatibility mode, disabled startup items, deleted AdobeFontfiles and removed the plugins from the Encore-Folder...
so basically everything I found on the Adobe troubleshooting page and in forums. It didn't help.
What else I can I try ?
I'm running Windows 7, 64 Bit on a Dell M6500,
Intel i7, 1,73 GHZ, 8GB Ram, with a NVIDIA QUADRO FX 3800M.
Thanks a lot for any suggestion!
Paul
Ricky Barrow
Re: Encore CS5 crashes a few seconds after starting
on Dec 7, 2011 at 6:27:31 pm
Check nvidia drivers
Ricky
John McHugh
on Jan 8, 2012 at 1:41:03 pm
I had about the same problem. What I started doing is to make a DVD image since I need a copy also. Once the image was created, it takes several minutes to burn the DVD.
I hope this helps.
