Problem in Encore linking up to Photoshop
COW Forums : Adobe Encore DVD
Kadshah Nagibe
on Nov 28, 2011 at 4:23:54 am
I watched Andrew Devis video "Adobe Encore Basics 2 Creating Menus"
but I ran into a problem. I right click in project submenu then edit menu in photoshop but photoshop doesn't come up instead I get a window that has file, edit, image and help that's it. I have photoshop CS5.1 64bit installed but right clicking in encore doesn't link up tophotoshop what should I do?
-kaj
http://sweetproductionmedia.com
Clayton Brown
Re: Problem in Encore linking up to Photoshop
on Nov 28, 2011 at 6:33:38 pm
Make sure that the menu you are saving and bringing into encore is a PSD- then when you import the file, make sure you 'import menu' -
with the menu selected- click edit, then 'edit menu in photoshop' -
Kadshah Nagibe
on Nov 28, 2011 at 7:46:34 pm
when i right click on NYSC project Submenu a menu comes which gives me the option of editing the menu in Photoshop I click on that photoshop is NOT loaded instead picture viewer is loaded. How can I get photoshop to load?
-kaj
Kadshah Nagibe
on Nov 28, 2011 at 8:09:43 pm
thanks Clayton for your help. I figured it out. Although I can't get photoshop to load from within Encore I'm able to load it directly from the shortcut on my desktop.
-kaj
