Is there a faster way of getting encore to produce SD versions of BD projects...
COW Forums : Adobe Encore DVD
Dan Ashton
on Nov 24, 2011 at 12:59:50 pm
...If you've already got the MPEG-2 DVD files rendered?
I'm looking to produce identical DVD products (menu structure, chaptering etc) from the BluRay Encore builds, but obviously this'll run through a transcoder - taking a fair bit longer than it does for me to just render the MPEGs myself.
Obviously I appreciate it's a fiddly request, since Encore does a half decent job of transcoding the BD files, it's just that a straight-swap of the HD video with the standard i've already produced would give a nicer looking result in a quarter of the time.
Any help would be appreciated, ta!
Chris Tompkins
Re: Is there a faster way of getting encore to produce SD versions of BD projects...
on Nov 24, 2011 at 5:09:43 pm
The best route would be to compressed the original media/master to SD mpeg2.
Import into Encore for authoring.
Chris Tompkins
Video Atlanta LLC
