Menu inside Title Safe still cropped
COW Forums : Adobe Encore DVD
Alan Coakley
on Nov 15, 2011 at 9:00:38 pm
Ice created a menu. All the buttons and titles are within the title safe area and yet they are still
cropped when I play the dvd on my tv. Its a headache. Why is that happening. Im playing the dvd on a widescreen television.
Alan Coakley
Re: Menu inside Title Safe still cropped
on Nov 15, 2011 at 10:33:24 pm
Ive actually solved the problem. I edited the menu in photoshop and Noticed that in the
"VIEW - PIixel aspect ratio" It was set to widescreen so i changed that to DV PAL.
Daniel Ludwig
on Nov 19, 2011 at 6:50:14 am
Alan,
what kind of DVD you are trying to create PAL or NTSC? 4:3 or 16:9? these are the major qestion at first, and which CS-suite you are using?
depending on the tv-standart the sceens have different resolutions:
PAL: 720x576
NTSC: 720x480
but adobe changed some informations on the pixel-aspec-ratios from CS4 to CS5.
if you are working with square pixels, you have 1024x576 for PAL (16:9) or 864x486 for NTSC (16:9), but adobe has changed these values from CS4 to CS5.
now they are different, for example PAL has now 1050x576 - this is confusing, your right, and a lot problems came with that idea as well.
cheers
danny
