Joining Slideshows While Keeping Transitions??
COW Forums : Adobe Encore DVD
Chris Wright
on Aug 29, 2011 at 5:46:31 pm
Hey there, I have a 320 image slideshow I'm building. Since I can only have up to 99 images per slideshow, I plan to use multiple slideshows and join them with end-actions. Here's the dilemma.....
I want to maintain the cross dissolve and random pan & zoom between each slideshow. Is that possible? Or do I have to settle for a cross dissolve to black at the end and beginning of each slideshow? Would just hate to have that black between slideshows though as it'll be inconsistent with the transition between the previous 99 images.
minu sharma
Re: Joining Slideshows While Keeping Transitions??
on Sep 5, 2011 at 9:51:14 am
Hi Chris ,
You can do this using Premiere pro .
Steps :
1. Import all stills in Premiere .
2. Create a sequence .
3. Now from effects panel make the transition you want to put as default transition.
4. Now select all the stills and from Project > Automate to sequence.
5.Now choose sequence and Export as Mpeg-DVD.
6. Import the exported files in encore and burn DVD
I hope this will help.
Minu
