Compressing video authoring to fit on Single Layer DVD
COW Forums : Adobe Encore DVD
Brent Dunn
on Aug 19, 2011 at 4:45:15 pm
Is there a way to compress the video more in Encore so it will fit a single layer DVD? I can't find any adjustments in the preferences or settings.
Right now I'm using Encore CS4 on a Mac. I have 1 hr & 40 minutes of HD ProRes edited footage. Encore will only compress it down to 5.6 Gig's, so I have to use a Dual Layer DVD. I have a client that requested it be put onto a single layer DVD. I have 4 pages of basice menu's.
Brent Dunn
Owner / Director / Editor
DunnRight Films
DunnRight Video.com
Video Marketing Toolbox.net
Sony EX-1,
Canon 5D Mark II
Canon 7D
Mac Pro Tower, Quad Core,
with Final Cut Studio
HP i7 Quad laptop
Adobe CS-5 Production Suite
Ricky Barrow
Re: Compressing video authoring to fit on Single Layer DVD
on Aug 19, 2011 at 5:30:08 pm
Adjust your transcode settings to custom or change to a different preset. For 1 hr. 40 min. with no ROM Content here are the settings to maximize quality:
100 min. PCM audio with 5% headroom = 4.4 Mbps
100 min. AC-3 audio with 5% headroom = 5.7 Mbps
100 min. PCM audio with 10% headroom = 4.1 Mbps
100 min. AC-3 audio with 10% headroom = 5.4 Mbps
Hope this helps - on PC, right click file to "Transcode Settings" and if you want to customize, go to "Edit Quality Presets"
Ricky
Brent Dunn
on Aug 19, 2011 at 6:19:22 pm
I'm on a Mac. Where in the Menu can I change the transcode settings?
Brent Dunn
DunnRight Films
DunnRight Video.com
Sony EX-1,
Canon 5D Mark II
Canon 7D
HP i7 Quad laptop
Ricky Barrow
on Aug 19, 2011 at 6:42:51 pm
Sorry - I don't know on MAC - the help menu will take you straight there though.
Ricky
minu sharma
on Sep 5, 2011 at 11:46:48 am
Hi Brent ,
You can do the following :
1. Go to File>Edit Quality Presets ..
2. Make changes in settings and save preset with a name.
3. Click ok.
4. Now from project panel , select asset right click and choose Transcode settings.
5. From DVD Transcoding dropdown choose the preset you created.
6. Click ok.
7. Do the same for all assets( if you have more)
8. Now go to build and check disc info. If it says the data is less than 4.7GB , it will fit in single layer.
Minu
