BluRay with HD Menues won't work
COW Forums : Adobe Encore DVD
Andrea Hofmann
on Aug 5, 2011 at 9:18:19 am
I've created a blu-ray project with nine HD menues (1920x1080, 72dpi, RGB) and 13 films in 1920x1080 29.97i mgeg2.
No error messages while burning, but the Bluray won't play in two different players.
If I build the same blu-ray project but with menues in 720x480 and still the same HDfilms, everything works fine.
Has anyone experience why this is? According to Adobe Encore, I'm able to use full HD menues..
Thanks for your help
Andrea
Daniel Ludwig
Re: BluRay with HD Menues won't work
on Aug 5, 2011 at 9:43:14 pm
hey andrea,
there are several reasons why you BD wont play on standalon-players.
- bad media
- to high bitrate
- standalone player can´t playback BD-R
I´ve created a lot BDs using adobe encore - also BDs that has gone to replication - they are all working fine.
I guess it´s depending on your encore-version. I have been using CS4 or CS5 and I know encore CS3 is a big, big mess...
I also would like to advice to use high quality media like verbatim or tayo juden.
habe you burned from within encore? if you burned these BDs with another burning-programm you might use the wrong file-format as well.
Blu-ray needs to have the UDF2.5-format.
cheers
danny
Andrea Hofmann
on Aug 8, 2011 at 12:39:34 pm
Hi Danny,
thank you for your help.
Probably the disc was bad, as it worked now with a different one.
Cheers
Andrea
